PXI
Initializing network Warning KERNEL.346543:eth-smc9: initialization failed
I faced a network configuration problem. I downloaded labview rt on remote machine. After that, the network setting is not possible. I got an error message below.
I tried IP reset and booting with flopy. but it didn't work. Anticipating fast reply. Thank you.
(3,968 Views)
I would like to get more information about your system.
are you using the 8156B controller?
was the controller working before with RT?
Which LabVIEW RT version are you using?
This problem sounds like a bad ethernet port configuration but I will need more information before doing my suggestion
Blasioz Valenzuela
(3,968 Views)
