PXI
MAX cannot auto-detect my SCXI cards in my PXI-1011 chassis.
I manually set up the SCXI-1140 cards and ran my labview program. The measured data was bad. I tracked down the problem and figured it was the chassis that had the problem. I wondered if the incorrect data was related to the auto-dectection problem of the chassis.
Thank you in advance for your help.
(3,982 Views)
Tin;
If you could narrow the problem down to a bad chassis, the bad data you acquired befored is definitely due to that bad chassis.
Regards
Filipe A.
(3,981 Views)
