PXI
Interfacing a BNC-2110/Picking a PXI card
Hi All,
I have several questions to get my system set up. Any help is greatly appreciated
Context: I have a PXI-8381 and an imec card (in a 1071 chassis, in slots 1 and 2, respectively) and I want to interface them with an BNC-2110 block to send TTL pulses over. Also, the documentation of my imec card recommends to use a PXIe-6535 to add a synchronization signal among all the NI devices, so
1-can I connect the BNC-2110 to a PXIe-6535?
2-if so, what cable do I need?
3 and, what slot in the chassis would be recommended to place the PXIe-6535?
if I cannot connect the BNC-2110 to a PXIe-6535:
4-what other PXI Digital I/O Module is recommended to interface the BNC-2110? Because, I will use it for synchronization purposes, the PXI should have a sample rate divisible with the sampling rate of the imec card (40kHz).
Thanks in advance.
Best,
Miguel
Message 1 of 1
(954 Views)
