PXI
Is there a chance to install Windows 10 (64-bit) on a PXI-8108?
I am facing the request that the operating system on a PXI-8108 needs to move to Windows 10 (on account of a company rule).  Has anyone already done so?  Do I have to expect any issues?
(4,911 Views)
Hello GuenterMueller,
offically no. The situation is that windows 10 can be installed on the controller and most things are working. What i can not guarantee, is that all peripheral drivers (GPIB, ExpressSlot, network adapter and so on) are working, because the latest tested version for this driver was windows 7.
Please also update the BIOS before you test.
best regards
Alexander
(4,889 Views)
Thanks, Alexander: Your answer comes as no surprise.
By the way: Are there any PXI Controllers that officially support Windows 10?  And, best of all, compatible to the PXI-8108?
(4,873 Views)
Accepted by topic author GuenterMueller
you can use the PXI-8840.
best regards
Alexander
(4,869 Views)
Immediate answer.  Thanks, Alexander.
(4,865 Views)
Can we revive this subject again? Windows 10 (32-Bit) still not compatible with PXI-8108?
(2,770 Views)
