PXI
PXIe-2525 in Switch Executive
Hello Community!
I'm new to Switch Executive and there are a few things that I can't solve on my own.
PXIe-2525 / 2-wire Octal 8x1 mux topology. To my best understanding, in order to create Bank0 (in red below) & Bank 1 (in green), kbc01 & kbc23 should be closed.
I want to connect Bank 1 , ch12 for example, to Com 0 bus, kbc02 need to be closed. Please correct me if I wrong so far...
How can I configure this scenario in Switch Executive?
part of PXIe-2525 HW diagrampart of PXIe-2525 HW diagram
Any help will be much appreciated!
(1,449 Views)
The idea seems right.
I wonder what is your question, you want to know how to operate the Switch Executive?
Could you please show what you see on your screen when the Switch Executive is opened?
__________________________________________
The best way to thank, is to give KUDOS
(1,375 Views)
Attached screenshot from Switch Executive.
Basically yes, I want to know how to operate the Switch Executive, how to configure connection between 2 banks.
I've tried to create hardwire between coms of 2 banks (screenshot attached), not sure if its the right solution.
(1,358 Views)
