PXI
LabView Error on PXIe-6537
I am currently running into LabView issues where all scripts I'm running do not get pass an error. My current setup is a PXIe-1073 along with four cards: PXIe-6738, PXIe-6537, PXIe-6361, PXI-8431. I'm wondering if it's a driver issue that the PXIe-6537 is not able to interface with the computer since the errors I get so far is consistent with that specific card, or is this a user-defined error code. However, I'm able to see slots on NI MAX and it seems to be able to see it on my Device Manager. Any help would be greatly appreciated, thanks! Attached are images of the same issue I'm running into.
Message 1 of 1
(982 Views)
