PXI
pxie-5451 CLK OUT output
How can I activate the clock out (CLK OUT) output (SMA) on the front panel? Any examples available?
(1,481 Views)
Use the Export Signal API to export signal to the CLK OUT connector,
Santhosh
Soliton Technologies
(1,441 Views)
Thank you! Would you happen to have any examples of implementation?
(1,425 Views)
I don't have specific examples, you can use the API with any of the shipping examples of FGEN or your existing code.
Anyway, I just added the API call to a shipping example to show how you could potentially use it.
Caution! - I did not have the HW to verify the functionality, it would be your responsibility to test/debug the VI.
Santhosh
(1,415 Views)
Thank you, I appreciate your help.
Maciej
(1,406 Views)
