PXI
Logical names in PXIe-2532
I'm working in a project with a PXI 2532 configured as 2-wire 4x64 in Labview, it would be possible to give names to rows and columns to something different than r0..r3 and c0..c64? I think it will add more clarity to my programming.
I tried the Property node object as write object, but as soon as I select Logical Name (under inherent IVI Attributes -> Advanced Sesion Information -> Logical Name), the object switches to a reading object.
(509 Views)
You will need NI Switch Executive to do this but not just with the NI-Switch driver.
Santhosh
Soliton Technologies
(490 Views)
$439 to change the names!
probably not happenning, but thanks for the info anyway 😊
(485 Views)
