PXI
PXIe6570 python API
I have problem by using the python api for PXIe6570.
I have just bought a PXIe6570 and installed it in PXIe1075, the digital pattern driver is installed and by using digital pattern voltage I can force voltage to corresponding channels. However, with python I can not drive the PXIe. It give the following erroe message: nidigital.errors.DriverError: -1074107500: Could not connect to the NI Route Coordinator service. Ensure that the NI Route Coordinator service is installed and started.
is it because of lacking any drivers?
thanks a lot!
(758 Views)
Here is a related topic - https://forums.ni.com/t5/NI-Package-Manager-NIPM/national-instruments-route-coordinator/td-p/3994372
Santhosh
Soliton Technologies
(740 Views)
Hi, thanks a lot for the reply.
however, my problem is not memory leakage with the route coordinator. I could not even start the route coordinate. When I want to start this service I get following error:
(699 Views)
Looks like your windows login account may have privilege issues to run this service successfully. Please try logging in as admin.
https://stackoverflow.com/questions/25619112/how-do-i-fix-the-error1069-the-service-did-not-start-du...
Santhosh
(688 Views)
