PXI
Malfunctioning of NI PXIe 1078 Chassis
Hi all
I am using NI PXIe-1078 chassis with PXIe-8880 controller for some time without any issue. However, recently i am facing a problem that as soon as I power ON chassis, it starts to ON/OFF PXIe-8880 controller again and again. First I thought that window7 based PXIe- 8880 has some issue so i checked it with another chassis (PXIe 1071) where it works quite fine. However, as  I insert this controller in PXIe-1078 chassis, again controller starts ON/OFF again and again.
Kindly help me what can be possible causes and how should i check PXIe-1078 chassis thoroughly?
Thanks & Regards
Message 1 of 1
(1,357 Views)
