PXI
PXI-5441 generates differential signal
I want to use PXI-5441 to generate differential signal, may I know which accessaries need to be used?
(2,458 Views)
Since you may generate LVDS signals only on Data Outputs, DDC CLK OUT, and PFI<4..5 you might need SMA cables or VHDCI cable+Terminal block.
https://www.ni.com/docs/en-US/bundle/374063b/resource/374063b.pdf
https://www.ni.com/en-us/support/model.shc68-c68-d3-cable.html
(2,241 Views)
