Hi Walking,
There are a couple of things to check:
- Have you identified the chassis in MAX? Or does it show up as "Unidentified"? Since you are using a MXI connection, please identify the chassis as an External PC.
- What version of the "PXI Platform Services" do you have? If it is below the current version (2.4) please update your driver here.
- Does the module show up if you try it in a different slot?
Message Edited by Seth B. on 12-05-2008 12:46 PM
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
