PXI
Memory option for PXIe-8862
New PXIe-8862 is planned to replace our previous controller for faster processing.  Currently, PXIe-8861 has been used with 32GB memory.  Though CPU on PXIe-8862 is a more latest version than the one on PXIe-8861, it looks like PXIe-8862 supports only up to 16GB for its memory option, according to the following specification page.
https://www.ni.com/docs/en-US/bundle/pxie-8822-specifications/page/overview.html#GUID-F300DD62-70AC-...
Any chance to install two 16GB memories to make it 32GB in total on PXIe-8862, or motherboard on PXIe-8862 limits it up to 16GB?
16GB max for memory option sounds a bit short for latest PCs for measurements and controls.
(2,209 Views)
Accepted by UMASO
Yes, you can install 32GB as described in the brackets in your image (2 x 16GB maximum) though 16GB is the standard option.
Santhosh
Soliton Technologies
(2,175 Views)
Thanks much for the reply.  I somehow misread the description and thought 16GB was the max for 8862 memory.
(2,151 Views)
