PXI
Mxi over usb 3.0
Hi!
Has anyone used a usb adapter for mxi card to control a PXI chassis? Furthermore, I can only find usb 2.0 adapters which are inadequate in throughput.
USB 2.0:
http://usb.brando.com/mini-usb-to-express-card-adapter-cable_p00783c0032d015.html
(9,754 Views)
Accepted by topic author MagnusAF
Sorry, you are probably out of luck.
The PXI works as an extension of the PCI / PXI also for external PXI boards in an external mainframe. Ie the connection required is a type of PCI / PCIe bridge / extender. The devices in the external mainframe must be recognised by the computer as PXI / PXIe units at boot time or drivers won't work.
The "native" ExpressCard slot is a direct extention of the internal PCIe and will therefore usually work. Usually, because the PC / laptop must ALSO have a BIOS that recognises external PCI/PCIe devices. Many newer laptops and stationary PCs from major manufacturers like HP and Dell support this.
An ExpressCards that connects via a USB port (external or internal) will never work.
Your options are
- Use a PC with PCI / PCIe slots (and BIOS support for external devices) + PCI / PCIe extension card
- Use a Laptop with native ExpressCard slot and BIOS support + PCIe extension card
- Use a controller in the PXI rack
Perhaps your laptops have some un-used internal slot to mount an ExpressCard slot?
(The above is untess things have changed recently)
(9,751 Views)
Thank you for your quick response!
The problem is that the company wants to use standard computers without the expresscard slot. I guess the solution will be to use a stationary or negoitiate an exception for the laptop
Thanks again!
(9,747 Views)
If you try persuade them, you might want to tell them that the ExpressCard does not require any software / drivers in addition to the normal NI drivers for the PXI devices.
(9,737 Views)
Hi
I have only old Laptop HP ProBook 6570b with windows 7 and it has PCI-port, I think it is same as PCMCIA port
If I order old ExpressCard-8360 from Artisantg.com and MXI Cable 779500-03 from eBay do I have needed hardware?
Do I have possibility to control my VNA  NI PXIe-5632 in PXI rack which has PXIe-8360 link card
Is that software NIVNA1800 ok for that?
-Hannu
(882 Views)
