PXI
NI 6071E
Hi everyone,
I just start to work with NI card and Matlab.
My problem is I tried to send a sine wave for stimulation. For simplicity, my analog output is first connected to my analog input. I want to test the delay in trigger. I got it. But I don't know how to verify the analog input function (i.e. Is it the same function that I sent?). All I can get is a straight line at -5V.
Does anyone have any idea about this?
My code is following:
ai = analoginput(
'nidaq', 4); addchannel(ai, 1);
ao = analogoutput('nidaq', 4); addchannel(ao, 0);
set ([ai ao],
'TriggerType', 'Manual');
set(ai,
'ManualTriggerHwOn', 'Trigger');
duration = 4;
set (ao, 'SampleRate', 10000);
ActualRate = get(ao,
'SampleRate');
len = ActualRate * duration;
data = sin(-pi:0.01:pi)';
putdata (ao, data);
start ([ai ao]);
trigger ([ai ao]);
% Determine the starting time for each device object...
%Acquire data from input
gData = getdata(ai);
plot (gData);
------------- Thank you very much.
(3,295 Views)
Your code looks fine.  Are you running single ended or differential?  You should double check your wiriing.  Put a known source on the input and see if you can see it in M&A Explorer and MATLAB.  Put a scope on your output and verify that the signal is being transmitted as expected.
-Rob
Rob Purser
Manager, Test and Measurement
MathWorks
rob.purser@mathworks.com
(3,283 Views)
