10-17-2007 09:15 AM
10-18-2007 08:00 PM
Hello Talwar,
Thanks for contacting National Instruments.
The PXI 4072 was designed for performing measurements on discrete components. It uses a multi-tone AC signal to perform inductance and capacitance measurements. The knowledgebase Can the NI PXI-4072 FlexDMM & LCR Meter Perform Impedance Measurements? outlines the method in detail.
The PXI 4072 is capable of measuring waveforms at a sample rate of up to 1.8 MegaSamples/second. Pages 8 and 9 of the specifications sheet shows the available sample rates as well as the bits of resolution compared to the sampling rate. There are several shipping examples in LabVIEW that are great starting points for performing waveform acquisition with the PXI 4072. These can be found in Help -> Find Examples and then by browsing to the path Hardware Input and Output -> Modular Instruments -> NI-DMM -> Acquiring Waveforms. If you wish to acquire the waveform continuously, the knowledgebase Can I Perform Continuous Acquisitions with my DMM in Waveform Mode? provides useful getting started information.
Please post back if you have any questions. Have a great day!
