10-15-2007 06:38 AM
10-17-2007 07:31 AM
Hi Malcolm,
Unfortunately no one in the technical support office here at National Instruments UK has any experience with using a PXI chassis in a heated confined space so the only advice I can give is to make sure that you work within the hardware’s recommended operating range, which from the datasheet is 0 oC to 50oC for the PXI-1031 Chassis. If you have any more specific questions regarding any aspect of your system that I can help you with, please don't hesitate to ask.
Best of luck with your application and apologies for not having more of an input for you,
Ian C.
10-18-2007 08:37 AM
