PXI
NI Max simulated PXI device not present in Labview project
I've added a simulated NI-PXI-6527 digital IO card to my PXI in NI MAX, but it does not seem possible to access this simulated IO card in a Labview project.
Is this normal ?
(4,608 Views)
Hi morngoose,
The Red Circle with an X makes me think that it is not possible or configuration settings have changed. Can you walk us through how you got to the point you're at in the screen shot?
- Kale
(4,577 Views)
Accepted by morngoose
Got it sorted.
Turns out the DAQ driver on my desktop and PXI was not the same version.
UPdated the PXI, and then it worked.
Cheers
(4,552 Views)
