PXI
NI PXI 1044 monitoring board
I use many chassis and boards ( NI PXI 1044 / 8360 / 6704 / 6509 / 6220 ) driven by RTC Linux Computer, and I would like to monitor them. What I just want to know is their status ( start / stop / error ).
Is a way to do that ? Simply without soft installation ?
What I currently use is this command :   nilsdev  which returns the list of the board known by the computer.
What could be better will be to have status information.
Thank you for your help.
(1,386 Views)
To access the status of the hardware, you would need to open a session to it. This can only be done with a driver. What you can do it to modify the existing program to update the status proactively, e.g. via UDP/TCP or write to a text file which another user can read.
https://tmesystems.net/
(1,364 Views)
