PXI
NI PXI-6255, differential terminal configuration. How to call ch16-23?
I'm using channels 0-7 and 16-17. How to call ch16-23?
String PXI1Slot5/ai0:7, PXI1Slot5/ai16:17 doesn't work (says channel 16 doesn't exist).
String PXI1Slot5/ai0:7 works.
String PXI1Slot5/ai16:17 doesn't work (says channel 16 doesn't exist).
(2,843 Views)
Did you do any configuration of the board in MAX?  It is sounding like you somehow disabled the second connector.
GCentral
(2,835 Views)
I haven't changed the configuration in MAX, so everything should be by default. But I'll check, thanks for a good hint.
(2,828 Views)
There was my mistake in a PXI slot number, so the whole topic doesn't make sense and can be removed.
(2,786 Views)
