PXI
NI PXIe4303 connector query
Can you please help me identify the type, class and manufacturer of the "96-pin male DIN 41612/IEC 60603-2 I/O connector" as mentioned under the heading of Physical Requirements in the datasheet of PXIe4303 (http://www.ni.com/pdf/manuals/377007b.pdf , page 16)
Also, please assist me in finding the matting part for this connector
(2,589 Views)
Hi naihapervez,
I'm not sure if I understood your question completely, but I think you have the answer for the type and class right there "DIN 41612/IEC 60603-2" that would be the standard of the connector. For the manufacturer, I would recommend calling National Instruments' support to see if that information can be given to you.
The accessories for this card are the TB-4302 and TB-4302C, as you can see here.
Regards.
(2,562 Views)
