PXI
OPC Help
I want to be able to have a NI-PXIe 8135 talk to the NI OPC server so I can in turn have GEs iFIX talk to the NI OPC server and us it as the HMI.
PXIe-8135 <->NI OPC Server <->iFIX
I am running Labview 2017. I bought the HIL and Real-Time Test Software Suite ( https://www.ni.com/en-us/shop/product/hil-and-real-time-test-software-suite.html) and the NI OPC server (http://sine.ni.com/nips/cds/view/p/lang/en/nid/209059).
According to https://www.ni.com/docs/en-US/bundle/labview-opc-ua-toolkit-api-ref/page/opcuavis/opcua_pal.html, "You must activate the LabVIEW Real-Time Module to use the OPC UA VIs on a real-time target"
I have the LabView Real-Time Module activated.
Do I actually need the Labview OPC UA Toolkit (https://www.ni.com/en-us/shop/product/labview-opc-ua-toolkit.html) for these VIs? They do not current show up in "C:\Program Files (x86)\National Instruments\LabVIEW 2017\examples\comm". Plus if I right click on the real-time target in Labview and select New -> I/O Server, I do not see OPC as an option (only EPICS).
Or is there a simpler way to connect to iFIX to get the data off of the PXIe?
(5,808 Views)
Accepted by topic author JustinWelch
Justin,
Short answer: yes.
You have linked to the LabVIEW 2016 Help. From 2013-2016, OPC UA VIs were included in the LabVIEW Real-Time and DSC Modules. in LabVIEW 2017, they were separated into their own OPC UA Toolkit.
OPC with LabVIEW Software Options
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MwxSAE&l=en-US
(5,793 Views)
Thank you for your reply.
If I am reading about DataSocket correctly though, I should be able to communicate using that? By communicate I mean that I could have an HMI (GE's iFIX) read/write data to the PXIe?
Is there a good guide somewhere that explains how to use that functionality?
(5,786 Views)
Justin,
Here are a few articles about establishing that connection:
DataSocket Connections for OPC Items
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7fWSAS&l=en-US
Connecting LabVIEW to an OPC Server Using Front Panel DataSocket
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2C7CAI&l=en-US
(5,765 Views)
I bought the OPC Toolkit, dowloaded, installed, and activated.
I would have thought that this meant if I right-clicked on my device, go to NEW>> I/O Server and see OPC Client. All I see is EPICS and Modbus.
If I try to downal the OPC UA Demo project, I get the following error.
Failed to load shared library bi_opcua.*:
niopcua_client)closeClient:C.
Put simply, I want to have my variables in my program read by an OPC Server. Any suggestions on what else I need to do to set it up?
(5,680 Views)
Justin,
In the LabVIEW OPC UA Toolkit, this is done programmatically. Look through the tutorial below, which has examples on how to do so:
Tutorial: Creating an OPC UA Server and an OPC UA Client
https://www.ni.com/docs/en-US/bundle/labview-opc-ua-toolkit-api-ref/page/opcuatool/creating_opcua_sv...
(5,675 Views)
