PXI
NI-SYNC measure Frequency crashes LabVIEW
I have reproducible crashes of LabVIEW when I used the NI-SYNC measure frequency vi and do a NI-TClk sync acquisition on two boards with NI-Scope. The crash occurs when I try to close the NI-Sync in my software. LabVIEW simply vanish without any noise, notice or warning :-(.
My System :
PXI 1042Q
PXI8360 (driver 1.0.2f0 on XP)
PXI6552 (NI-SYNC3.1)
PXI5922
PXI5124 (NI-Scope 3.5.2 andNI-TClk 1.7.1)
I run into it with LabVIEW 8.6.1 , then tried the software on a similar system (1045 with 8336, 5922,5124,...) with 2009f2 and it runs fine.
So I upgraded to 2009f2 but it still crashes..
I attach a zip of my crashtest
run the vi, setup the devices in the setup-tap and hit one of the two buttons to execute lists of indicated actions. The one including the 6552 measure frequency causes the crashes.
Message Edited by Henrik Volkers on 11-25-2009 03:53 PM
Greetings from Germany
Henrik
LV since v3.1
(3,585 Views)
Updated a thrid system to 2009 (1042Q,8336,5922,5122) and no crash 😕
Seems that there is something wrong in the first system, maybe the 8360???    .... any hint what logfiles or NI-Spy settings could put some light on this?
Henrik
LV since v3.1
(3,570 Views)
Hi Hendrick,
did you try a clean installation on the first system?
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(3,471 Views)
