PXI
Need FPGA code
I am using PXI-1062Q chassis,PXI-e8135 embeded controller, NI PXI-7831R card. I have installed max 2024 ,my question is this PXI-7831R compatible with my labview version? and I need some FPGA code or an example to make sure that I am able to do anything with my card.
(1,110 Views)
See https://www.ni.com/en/support/documentation/compatibility/21/ni-hardware-and-operating-system-compat...
and
https://www.ni.com/en/support/documentation/compatibility/09/software-support-for-compactrio--compac...
I checked LabVIEW 2024Q3 32-bit and I cannot create a PXI-7831.  You will need to use an older version.  I am not sure which is the latest version but it goes as far back as 2016.  I recommend reaching out to NI support to get a detailed answer.
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,080 Views)
Accepted by helenhnhn@gmail.com
The second link is correct. The support for PXI-7831R was removed in 2017.
NI R Series Multifunction RIO Device Drivers May 2017 Readme
  • NI R Series Multifunction RIO Device Drivers May 2017 no longer supports the following devices:
    • PCI-7830R
    • PCI-7831R
    • PCI-7833R
    • PXI-7830R
    • PXI-7831R
    • PXI-7833R
If you still want to use PXI-7831R, the latest supported version is LabVIEW 2016 and NI-R Series RIO 16.5.
https://tmesystems.net/
(1,072 Views)
