PXI
Nidaq32.dll not registred when used after 7.4&Labview installation
In my Pxi 1042 module recently i've installed labview 7.1 and conseguently NiDaq 7.4.
In using labview application I've no problem. Instead by attempting using a self-made
program in visual basic to acquire analog signal from a pxi-6052E module I've encountered
the problem that none module is found even if in Measurament&Automation (3.1.1) I can test
every channel correctly.
In debugging visual basic program the reason is that nidaq32.dll file is not found.
However the file is correctly in this path c:\windows\system32.
The first try to resolve this problem was the registration of nidaq32.dll but this was the result:
"c:\windows\nidaq32.dll was loaded, but the DllRegisterServer entry point was not found. The
file can not be registered".
In order to avoid the problem eventually due to the labview installation I've disinstalled labview
and all other ni programs by MsiBlast.exe.
After I've reinstalled NiDaq 7.3 only, but the result is always the same.
I've also to say thet my acquisition program written in visual basic  worked before the installation of
labview with Nidaq 7.3.
What about more?
I've no-idea how to resolve this problem.
Help me
Thanks.
Massimiliano.
(3,204 Views)
Find a potential solution to this problem on the following web page:
http://digital.ni.com/public.nsf/websearch/6A73AE4A1104639686256C460081528C?OpenDocument
AlessioD
(3,201 Views)
Thanks.
Problem solved
(3,190 Views)
