PXI
No driver for PXI-8512
I have a PXIe-1078 chassis with an embedded controller and a PXI-8512 CAN card installed.  When I look at MAX, the CAN card shows that
'Windows does not have a driver associated with your device'
I have the NI-XNET 18 and runtime, and NI-CAN installed and have tried the card in another slot in the chassis.
Is there another step I need to carry out to get the chassis to recognise my card?
Dave
(4,346 Views)
Hey Dave,
Looks like un-installing NI-CAN could solve your issue. It's not needed, as NI-XNET is the replacement for NI-CAN. See Migrating NI-CAN Applications to NI-XNET for more detail.
Thank you for posting the screenshot, that helped a lot when checking if there are other devices in your PXIe that need the CAN driver (there are not). Also, the PXI (without "e") card is in a correct slot, it needs to be in either slot 4, 5, or 6 on your hybrid chassis.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(4,324 Views)
Accepted by djroseman
Thanks for that info,
Following removing NI-CAN and then also uninstalling XNET as well, then reinstalling, my card is now recognised correctly.
Thanks again,
Dave
(4,316 Views)
Good to know it worked out, thank you very much for posting the result. Please mark your last reply as correct answer of this thread, so others having the same problem can find the solution faster!
CLADMSD
(4,313 Views)
