PXI
Noisy waveforms from pxi-6552
I’m using the pxi-6552 Digital I/O card at its max speed (100MHz) and I am having problems generating a clean waveform. I have NI proprietary cable and interface board connected to the DIO card and probing directly on the headers on the interface board. The cable is about 3 feet in length. Does anyone have any ideas on how to either generate a cleaner signal or clean up the signal I am generating?
Can anyone help with this?
-Milhouse
(3,320 Views)
Hello Millhouse,
We have a great article called Field Wiring and Noise Considerations for Analog Signals that explains methods of reducing noise.  I hope this helps.
Roman S
Roman Sandoval | National Instruments | RF Systems Engineer
(3,298 Views)
