PXI
Outputing an analog waveform in the PXI-6052E
I Have a 6052E and a 6733 Analog output card. I would like to be able to output a waveform from either of these.
The waveforms would be normally multiple waveforms with some degree of phase shifts etc. Generating a waveform is simple enough.
I have tried to output a wf on the 6052E AO channels 0 and 1. I noticed on the scope that there was a lot of jitter on these signals. Maybe I am not doing it correctly.  The wf I am using at the moment is a square wave -6 to +6 Volts. (I use the analog ports because I need to generate "digital" waveforms of different voltages )
Can somebody give me some guidance as how to do this properly?
what type of timing should I use? Finite or continous generation? rates etc
In the future I would like to use the 6733 also and have it in sync with the 6052E. Any suggestions as to how to do this?
(3,626 Views)
But which software are you using?? LabVIEW? CVI?? others??
Your post gives no indication on that Smiley Wink
(3,616 Views)
(3,616 Views)
I am using Labview 7.1 / Max 3.1.1. Sorry
(3,612 Views)
I hope you are using DAQmx Drivers
Apart form learning from the Example VI' that are shipped with your LabVIEW, Find Examples>> hardware input output>>DAQmx>> Analog Generation>> Voltage folder, you could see this and this example vi's. [broken links removed; examples no longer online]
In your LabVIEW, Find Examples>> hardware input output>>DAQmx>> synchronization>>Multidevice, you will find example vi's to perform Multi device synchronization. ( I guess RTSI sync will work for PXI 6733)
(3,598 Views)
