PXI
PCIe-5764 Matlab compatibility and external triggering
Hello everyone!
I'm going to by 4ch fast digitizer and my sight was dropped at 5764 model.
Could you say, is it compatible with Matlab?? I didn't find this model in NI-SCOPE , Data Acquisition Toolbox device list.
There s no special external trigger input, instead of this exist digital IO connector. How external triggering could be provide??
I also didnt find any Programming manual on this model.
Thanks.
(2,111 Views)
Check the getting started guide for the 5764: http://www.ni.com/pdf/manuals/376460b.pdf
PXIe and PCIe should be very similar.  I believe you will need LabVIEW FPGA and NI FlexRIO drivers to run this card.
Do you have plans for what you will run on the FPGA?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(2,099 Views)
Thanks for answer.
I checked this manual before and was surprised that theres no separate programming manual like for digitizers from another vendors.
I need to run digitizer under Matlab applications.
-Do you have plans for what you will run on the FPGA?
No matter how strange it sounds, but I need to collect 4ch data with following postprocessing steps.
(2,060 Views)
