PXI
PXIe-8135 first start problem
Hi everyone,
I bought PXIe-8135 Controller recently. When I start up the system, the following interface appears and I don't know how to deal with it.
Best Regards
Young
(2,594 Views)
Accepted by topic author Young365
Hi Young365, your PXI controller is working as Real-Time (RT) OS. It's normal if you purchased the controler as RT.
We can select which OS will be there on ni.com.
Do you want to use it as Windows? There are some options as below.
Change or Update the Windows OS on PXI(e) Controller
About "DUAL BOOT"
Dual-Boot Windows 10 and Real Time Operating Systems on NI PXIe Controllers
Due to differences in frameworks of Windows 10 and RT operating systems, PXIe controllers can not be dual booted with both Windows 10 and a RT OS.
Dual-Boot Windows 7 and LabVIEW Real Time on a PXI Controller
- Purchasing a dual-boot controller
- Changing an existing controller to be dual-boot by dividing the hard drive into two partitions
Certified LabVIEW Developer
GCentral
(2,588 Views)
thank you so much!
(2,568 Views)
