05-08-2017 10:38 AM
hi,
I am new to PXI controller and chassis. I have PXI 1042 chassis , PXI 8187 controller and daq cards on its slots. can anyone please help to configure from scratch and its lan connection (crossed or straight cable). which latest LabVIEW rt is supported by this controller.
windows 10 64 bit is installed on host pc.
and can i run simulink models in real time mode in this contoller.
thanks
Solved! Go to Solution.
05-09-2017
11:10 AM
- last edited on
03-26-2025
08:32 AM
by
Content Cleaner
You can use LabVIEW Real Time module on this controller. The latest version is 2016.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YILGCA4&l=en-US
https://www.ni.com/en/support/downloads/software-products/download.labview-real-time-module.html
In regards of the simulink models here is a KB explaining about it:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHwKCAW&l=en-US
05-10-2017 05:13 AM
thank you for reply but i have some more fundamental questions.
1. chassis 1042 with (pxi controller 8187 and pxi card ) is not detected in host pc
i am trying lan cable with cross connections and straight connections . but both cases i cannot see any indication of connection.
2. host pc has LV14, MAX 14,
3. i tried from MAX -> devices and interfaces-> identify as --> 8187 (identified but not .... pxisys.ini etc)
4. is there any way to check connection of host pc with controller.
05-10-2017 05:52 PM
Hello Dmic,
I really recommend that you post these specific questions in a new forum, because I have answered some of your questions related to RT, however there are people more experienced with PXI chassis itself. If you create a new forum this one will go to the proper customers/engineers more familiar with PXI chassis. They can help you better.
