05-11-2017 10:31 AM
I have some fundamental questions regarding basic configuration and connection settings after unpacking.
1. chassis 1042 with (pxi controller 8187 and pxi card ) is not detected in host pc
i am trying lan cable with cross connections and straight connections . but both cases i cannot see any indication of connection.
2. host pc has LV14, MAX 14,
3. i tried from MAX -> devices and interfaces-> identify as --> 8187 (identified but not .... pxisys.ini etc)
4. is there any way to check connection of host pc with controller.
5. should I create new connection in host PC or it will work when I plug in the LAN cable
thanks
05-12-2017
01:33 PM
- last edited on
08-23-2025
04:49 PM
by
Content Cleaner
hey DMic,
Check the Device manager in windows and see if it shows up there
make sure you have the driver for the pxi chassis and controller
https://www.ni.com/en/support/downloads/drivers/download.pxi-platform-services.html#307297
have you checked the installation guide for that PXI?
here it is
https://www.ni.com/docs/en-US/bundle/323683b/resource/323683b.pdf
And also the user manual
https://www.ni.com/docs/en-US/bundle/370747c/resource/370747c.pdf
