PXI
PXI-4065 error code -233900
Hello members,
I have a PXI 1078 Chassis, using the boards:
NI PXIe-8360
NI PXIe-2527
NI PXI-4065
NI PXI-2569
NI PXI-6704
And I'm using computer with windows 10, 64 bit. The computer had already installed the drivers and was ready for use it.
  1. But after several days with the computer turned off, when I try to use it, the PXI was not detected by the NI MAX, In the device manager I don't see any boards, I check the connections, all was good. At the end I move the PCIe board in the computer to other port and reinstall the drivers and now I was able to see all boards in the device manager, without errors. But in NI MAX PXI-4065 all time show the error -233900. I swap the PXI-2569 with the PXI-4065 but again PXI-4065 continue with error and PXI-2569 was detected properly.
  2. I have other computer that already have same setup of drivers and when I connect this computer for a test with the PXI, I was able to see all boards, NI MAX was working good and the front panel for the DMM also.
  3. So I return to the original computer and keep same error -233900, I check some problems similar in the forum about don't detect a PXI board. And I uninstall all drives, do the installation again, but same result, also I try with the reset of database and same result. Also I try current DMM drivers, but same result.
  4. I get a new computer and I did again the installation, but at the end get same result.
For this setup the drivers used are: NI-DAQmx 16.1, NI-DMM 15.2, NI-SWITCH 16.0
Do you know what means that error code -233900?, the description show hardware error but in test 2, was working good.
Below you can see the error -233900, due the updates, now I have Ni MAX 20.
Any suggestions are welcome.
(1,810 Views)
I uninstall all drivers in the original computer. I start again a new installation, I forget to say that I'm using TestStand 2014 and I still get the error.
Then I try to run the NI-MXI-Express BIOS Compatibility Software, but I get the warning of Multiple root buses detected.  So, I return the PCIe board in the computer to the original position, now the device manager see all boards, also NI MAX.
Regards
(1,765 Views)
