PXI
PXI 4065
Can you capture a 2 msec, 500 mv pulse ( output from an accelerometer) with a PXI 4065 ( set to 4.5 dig resolution= 3KS/sec ) without ext trigger?
So far my experimentation says NO but just want to make sure I'm not doing something wrong.
(7,216 Views)
You can use an Immediate trigger or a Software trigger.
(7,212 Views)
Are there any examples or KB on using/configuring SW triggers?  I'm guess there isn't any external connection.
(7,203 Views)
I'm assuming you are using LabVIEW here.  If not, then we'll have to look somewhere else.  But look in the LabVIEW Example Finder.  I did a serach for "DMM waveform" and found a little example called Fetch & Graph Waveform.vi.
(7,198 Views)
thxs...
(7,174 Views)
