08-02-2013 04:59 AM
Can you capture a 2 msec, 500 mv pulse ( output from an accelerometer) with a PXI 4065 ( set to 4.5 dig resolution= 3KS/sec ) without ext trigger?
So far my experimentation says NO but just want to make sure I'm not doing something wrong.
08-02-2013 07:30 AM
You can use an Immediate trigger or a Software trigger.
08-02-2013 10:14 AM
Are there any examples or KB on using/configuring SW triggers? I'm guess there isn't any external connection.
08-02-2013 12:15 PM
I'm assuming you are using LabVIEW here. If not, then we'll have to look somewhere else. But look in the LabVIEW Example Finder. I did a serach for "DMM waveform" and found a little example called Fetch & Graph Waveform.vi.
08-05-2013 10:55 AM
thxs...
