PXI
PXI-4071 calibration procedure version 3.3.1.0 errors.
Program calls for 5MOhm which isn't available with the 5720A.  And seems to be using the user supplied charted value for both the high and low limits, instead of calculating the limits for the DC Current check. Is there a way to fix this?  See attached datasheet.
(3,369 Views)
Andy:
Looking at the first page of your Cal report I see that the driver is NI-DMM 3.0.0. NI issued a warning about that driver. They replaced it with 3.0.2.
I don't know if 3.0.2 will fix your problem but it does work with the PXI-4071correctly here.
Give it a try!
(3,343 Views)
