PXI
Problem Connecting to the serial port on PXI 8106
I am currently trying to connect to the serial port on the PXI 8106 via RS232. However, when I try to run the Open Test VI for COM1 through MAX (PXI remotely) running on a PC, I received an error as below :
Return status code: 0xBFFF00A8
Status name: VI_ERROR_NPERMISSION
Access to the resource or remote machine is denied. This is due to lack of sufficient privileges for the current user or machine.
At the moment I am just doing a loopback testing just to ensure that the device interface is working fine before running my labview code. I am not sure what the problem is exactly, if it has got to do with the PXI or the computer itself. Could you please suggest some solutions to this matter?
Thank you.
(3,744 Views)
Accepted by topic author kierenz
I have managed to figure it out. It was not running on the right platform.
(3,741 Views)
