PXI
PXI-4110 positive current on channel 2
Hi.
I use the channel 2 of PXI-4110. In datasheet mentioned that ch2 use quadrant III. But when I insert resistor only  in ch2, the soft panel shows me the positive value of current on that channel but voltage was = -15V. I think that current must have negative value. How it is possible? Can anyone explain? Thanks.
Message 1 of 1
(872 Views)
