PXI
Pxi6542 not detected by MAX
hello,
I'm working on pxi 6542. I download the driver NI digital waveform generator/analyser need it. Later, i need to configure it and test it in MAX. The problem is my device 6542 doesn't appear under NI-DAQmx Devices, MAX did not detect the device. I have read the manual, it said just refresh MAX but i tried many times still not working..
Any help please
(1,299 Views)
Please follow steps here if they do not help then there should be something wrong with the module itself.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004B0jSAE&l=en-GB
(1,132 Views)
Try set "Reset configuration" in MAX.
(1,108 Views)
