PXI
PXI-4110 referenced to -10V
I need a four quadrant power supply. Can I reference the +20V isolated supply on a PXI-4110 to -10V to get a +/-10V supply?
Bob
(3,149 Views)
Hi Bob,
The PXI-4110 is only a single quadrant power supply.  For detailed information about this, please see the KnowledgeBase Why is the NI PXI-4110 Described as a Single Quadrant Power Supply?
As far as using the +20V isolated supply as a +/-10V supply, this should be fine.  According to the user manual:
"Any terminal on the isolated channels can be connected to ground. For safety reasons, all the terminals must be <60 VDC from ground."
Let us know if you have additional questions about this.
Laura
(3,133 Views)
