Hello Chris,
The drivers are usually free, independent of the LabVIEW version (as long as is current which 8.20 still is), and you do not need to upgrade but it will be helpful to know what RFSA and NI-TUNER driver version you have. You can find this on Measurement and Automation Explorer. Expand the section called "software" and select the proper driver. On the left, you will see the driver version.
I am attaching a NI-Tuner Program to make sure your attenuation is being applied.
1. Open this and run it with RF frequency of 12.5 MHz and span of 15 MHz (0 reference level).
2. Open the shipped example: "C:\Program Files\National Instruments\LabVIEW 8.2\examples\Spectral Measurements Toolset\niScope\SMT Configured Spectrum for niScope.vi"
3. Run it and if your unit is bad, you will see the spurs (you can use your external spectrum analyzer as well tuned at 15 MHz).
4. Make a note of the Attenuation.
5. Now change on the Attached program the RF Frequency to 15 MHz and Span of 20 MHz. Run it.
6. You should stop seeing the spurs if everything is working as your screenshots suggested.
7. Make a note of the Attenuation.
Thank you,
Gerardo O.
RF SW Engineering R&D
