PXI
PXI-6220 And Scan List
I want to acquire mutiple singnels with PXI-6620, and I see that a Scan List memory of 4095 entries is indicated in the data sheet. I want to program the Scan List with CVI, and what should I do? I cannot find anything about it in the DAQmx mannul.
Thanks!
(3,090 Views)
You can take a look at the examples we have that are included with NI-DAQ. You can find these examples in C:\Program Files\National Instruments\CVI70\samples\DAQmx. You can then program multiple scan lists depending on the application you want to do.
Hope this helps!
LA
(3,081 Views)
