PXI
PXI-6229 counter output
I was using the DAQMx test panel for PXI-6229 module with my PXI-6229  card. I couldn't find an option of routing the counter pulse generation output to different PFIs. It is locked at PFI12 for ctr0 and PFI13 to ctr1. Is there some way by which I can route to other PFIs in the test panel or do I have to write code for it.
I want to route ctr0 output to PFI10 and route PFI12 as a counter input to measure frequency.
Please let me know
Shiladitya
(3,645 Views)
Shiladitya,
The Test panels are designed for functional testing only, and do not necessarily expose all capabilities of the device. In order to route these signals to custom PFI lines, you would need to write code. In LabVIEW, this would be done using a DAQmx Channel Property Node. Simply wire the intended terminal to the CO.Pulse.Term property.
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,624 Views)
