PXI
PXI-6259
I calculated uncertainty measurements for a PXI-6259 card. How can I add the measurements to a report done in calibration executive?
Message 1 of 9
(5,714 Views)
Hi Df1904,
In the Calibration Executive Help file linked below
http://digital.ni.com/manuals.nsf/websearch/81A063AF6BDC757386257A100063E8E6
there is a section on Measurement Uncertainty. This section says
If you use instruments that do not have uncertainty files provided by Calibration Executive, you can create your own uncertainty files by using the template files. Template files named Calibrator Template.txt and DMM Template.txt are provided in their respective directories under Calibration Executive\Uncertainty.
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
Message 2 of 9
(5,694 Views)
Hello Sunaina K.,
I do not have the Template files you are describing. Where would I find them?
Message 3 of 9
(5,691 Views)
Hi Df1904,
The template files can be found in the file path ...\Calibration Executive\Uncertainty\Templates
Sunaina K.
Message 4 of 9
(5,681 Views)
The files are not in the location
Message 5 of 9
(5,678 Views)
Hi Df1904,
Can you take a screenshot of your directory? It should look something like this:
Travis Ann
Customer Education Product Marketing Manager
Message 6 of 9
(5,667 Views)
Here is the screen shoot. I noticed that I do not have the DMM'S and Calibrator Files.
Message 7 of 9
(5,659 Views)
Try running a repair of your Calibration Executive installation. Typically, a repair will replace files that may have not been installed when you initially installed the software.
Travis Ann
Message 8 of 9
(5,650 Views)
The files did not restore
Message 9 of 9
(5,618 Views)
