PXI
PXI 6552 Model?
I need to find out what PXI 6552 I have. These are the different 6552 available. I looked in MAX and could not figure out what type I have.
778539-01 NI PXI-6552 100 MHz, 1 Mb/ch Dig Wfm; Programmable; -2.0 to 5.5 V
778539-02 NI PXI-6552 100 MHz, 8 Mb/ch Dig Wfm; Programmable; -2.0 to 5.5 V
778539-03 NI PXI-6552 100 MHz, 64 Mb/ch Dig Wfm; Programmable; -2.0 to 5.5 V
I removed the card and looked and was hoping to find "778539-01..." but I did not find any similar number.
But I did find these numbers:
EF49E0
188524K-24L
189876G-03
EF5A26
E-P900-05-2379(A)
4610B
Can anyone tell me based on the numbers that I found, which NI PXI 6552 I have?
(4,717 Views)
Hi Vishvabandhu,
We checked your numbers and found you have the 1Mb/ch memory option.  You may also check the size of your onboard memory for your HSDIO device using this Community Example Code posted online.  More info can be found here. Thank you.
Kyle A.
Senior Applications Engineer
(4,710 Views)
