PXI
PXI 6509 physical connections
When using a PXI-6509 with a SCB-100,where are 96 gnd wires to be terminated. The scb-100 offers 96 positive terminals and only the two gnd terminals? Are the ground terminals all tied together and then terminatedat pins 50 and 100(GND)?
(3,190 Views)
Greetings,
Yes, pins 50 and 100 are internally connected. Furthermore, all of the device's digital lines are referenced to this ground.
Good luck with your application.
Spencer S.
(3,190 Views)
