PXI
PXI-6512
I am setting up a system which test I/O's of 2 different modules , one operates at 12 V and other operates at 24 V
The output voltage range for PXI-6512 module is -30 to 30 V .
I would like to know how can the O/P voltage level can be configured to 12 V and 24 V , can it be done through software configuration or separate power supply source must be used ?
Response will be highly appreciated .
Thank you
(2,776 Views)
Accepted by topic author Niranjan18
Each port has a VCC input that is used to set the output levels.  All the 6512 really has is a bunch of relays to connect the VCC to the output line.
(2,758 Views)
Thank you ,
Can you please direct me to get more knowledge on this , like were can I find info related to wiring and other technical stuff .
(2,741 Views)
A very simple search even with the horrible NI search engine quickly gives the information you need:
Specification
User Manual
(2,731 Views)
