PXI
PXI-6513 Digital Output Module | NI MAX Problem
Hello Everyone,
I have a PXI-6513 digital output module. I want to test this module by using NI MAX Test Panels (FYI). I installed NI MAX. I can see my module on NI MAX. There is no error. I set up the circut below according to DAQ NI 651x User Manual. When I measure the load with multimeter and open-close the power supply, I can't see any different on NI-MAX Test Panels. I have read all related forums and others. How can I see HIGH-LOW state on load? Can someone with previous experience in this matter help?
It can be because of using the trial version?
LabVIEW trial version: 2023 Q1
NI-DAQmx trial version: 2023 Q1
Message 1 of 1
(1,125 Views)
