PXI
Should 64-Channel Digital I/O Modules Only Use With Terminal Block and SCSI Connector?
Hello Everyone,
I have 64-Channel PXI 6511, 6512, 6513 Digital I/O Modules that use SCSI 100-Pin connector. I tried to test PXI 6513 only for port0/ine0. I set up example diagram according to the datasheet page 54. I used jumper to connection for P0.0, P0.COM and P0.GND. I used NI-MAX test panels . But ther is no change on the load.
My question is: Do I have to use terminal block and SCSI connector for measuring load. Can I measure using jumpers? Because my friend use terminal block + cable and can see load change. Could it be any other reason?
Message 1 of 1
(1,306 Views)
