PXI
PXI-6723 error code: 50400 in MAX
I am having trouble with the PXI-6723 card in MAX. It was in a hybrid slot of PXIe-1073 Chassis, which was installed by factory before shipment. I can find the card on device manager and MAX. But when I try to self-test/reset the card, this Error Code-50400 shows up. I tried to reboot the PC and controller, re-install the NI-Daqmx, neither of them work.
Could anyone please give me some help how to fix this problem?
Thanks!
Xin
(2,451 Views)
I have the same problem. Have you solved it yet? If you solved it, how did you solve it?
/Sam
(892 Views)
See NI-DAQmx Error -50400 or -223022 When Reading From PXI(e)/PCI(e) Devices in LabVIEW
If you are using an MXI chassis or controller, see MXI-Express Compatibility and Connectivity Troubleshooting Guide as well.
https://tmesystems.net/
(884 Views)
